I'm wondering what's the best way to simulate the deformation when something is put on a soft body in Houdini, like a person sitting on a couch. would Finite Elements work for this? or is there a better tool?
Soft Body/Cloth dynamics in Houdini
3861 5 2- uuLLFA
- 90 posts
- matthias_k
- 483 posts
If you do not need exact volume only some simple deformation…
maybe the ray sop can help.
Play the attached scene to see the effect.
Play with the “Cutoff frequency” of the smooth sop to have a wave around the contact.
Edited by matthias_k - Oct. 6, 2016 07:06:09
- uuLLFA
- 90 posts
- matthias_k
- 483 posts
Then you should better use dynamics/finite element solver.
See the “VolumePreservingSolid” example in the help file.
But you said:
…like a person sitting on a couch…
a “normal” couch is not watertight, if I'm right.
It is losing “air”, if you sit down on it.
The more or less correct way is then maybe using cloth and springs…
Have a look at this example, too:
https://www.sidefx.com/forum/topic/34936/?page=1 [sidefx.com]
it shows how to create a tension map
Edited by matthias_k - Oct. 6, 2016 14:40:10
- uuLLFA
- 90 posts
- matthias_k
- 483 posts
