Hello. I tried to Google the question, looked up on the forums, read the documentation, played with examples but I still cannot find the answer.
I am working on a worm. It is procedurally animated through Point Wrangles in a SOP context.
The problem is that I want to use the SOP animation to drive the Rest position on the Solid Object in the dopnet.
So I am trying to find the right way to do it, I tried something stupid which is Tetrahedralizing the animated mesh at each frame, that does not work, as I get a different arrangement of tets at every frame, and the simulation cannot match the initial tets to the rest positions. I get an exploding worm.
What workflow should I use?
When they show transferring animation using Rest positions on tutorials or example scene files, what they do is distorting the tetrahedralized mesh. I already have the animated mesh that is my problem.
I attach the simple scene file. I wrote some notes if you want to have a look.
Thank you.
Tetrahedralizing animation for FEM solver
2057 2 1- eulersson
- 7 posts
- Enivob
- 2561 posts
Your scene did not attach.
Have you reviewed Sam's work on this subject?
Here is a link to earthworm locomotion using FEM.
http://ihoudini.blogspot.com/2013/12/worm-locomotion-with-fem.html [ihoudini.blogspot.com]
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- eulersson
- 7 posts
Enivob
Thank you very much! Sorry to be mean and not reply it was really useful, thanks!
