houdini apprentice - import not working & can I test redshift with it?
   4427   2   0
I am testing houdini apprentice right now.
I can't import anything from blender - i use *.obj. I can import the files to 3D max demo for example.
All I get is an empty object - in the viewport I only see the 3d manipulator. I downloaded a random obj-file and it is working. The working obj file is triangulated. I should be able to import quads?
what I notice: In some cases if I enter the object in the shematic view / node view there it is red (thin lines 45°) and it says “timeblend1”. It also displays any number in the filename as $F (instead of 2). I use Win 10 64bit.
It is still my old PC, win 10, i7 920, 12GB ram, GTX 750ti - planning to buy a new one with 6800k + 64GB + GTX 1070 soon.
Other question: Can I try the demoversion of redshift 3d with apprentice?
Can I test redshift demo with indie?
Is the GTX 1070 already supported by redshift and houdini?
Edited by Saberraider - Oct. 12, 2016 05:53:51
solved - I had to uncheck “show sequences as one entry” - now everything is working… I was importing a obj seq of 2 files
No, you can not use Redshift with Apprentice.
Yes, you can use Redshift with Indie.
Yes, Redshift works fine with 1070GTX.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
