Hi
I have a fbx file exported from sketchup which i am trying to light and render in houdini (nc).
All the materials will have to be overridden without going into the imported subnetwork as it will be updated/replaced often.
after import some materials comes in applied to groups of primitives and some are applied at geometry level depending on how they were assigned in sketchup.
What i tried to do was create a new attribute called material_path and use an expression to rewrite the paths to the materials, something like: `strreplace(@shop_materialpath, “/imported_fbx”, “”)`. this changes the paths to the materials from /obj/imported_fbx/materials/* to /obj/materials/*.
Unfortunately it only seems to work on materials that applied by group, but when materialpaths are applied at object level they dont pick up the override.
sorry probably a confusing explaination.
also tried using the material style sheet, but i couldnt figure out how to make it work either.
What is the easiest way of overriding everything without digging into the subnet?
overriding object and group materials
1400 1 0- gustaf
- 1 posts
- circusmonkey
- 2624 posts
