I wonder if it is possible to cache a specified set of frames with the ROP Output Driver.
So f.e. I have an animated sequcence from 1-100 and I just want to cache frames 17, 38, 40, 65, 88-100. How does this work? I can't figure that out, I'm sure it must be super easy and I'm missing it.
ROP specific frames?
1997 2 0- Xue_Yue
- 56 posts
- malexander
- 5158 posts
You can add two Frame Dependency ROPs as outputs to the driver and merge them together with a Merge ROP. Then in the first Frame Dependency ROP, set the “Frame Depends On” parameter to “List of Frames” and set the #Frames to 4. Then enter 17,38,40 and 65 in the Frame Dependency 1-4 parameters. In the other Frame Dependency ROP, set the Frame Range parameter to 88 100 1. Then render the final Merge ROP.
- Xue_Yue
- 56 posts
