I'm trying to scatter points based on an alpha image, I found this tutorial, but it's based on the old scatter node. How can I achieve this with the new scatter node?
Thank you.
Scatter points from alpha
1881 1 0- uuLLFA
- 90 posts
- Enivob
- 2537 posts
Drop down an AttributeFromMap before the Scatter. Then set the density variable to whatever you chose in the AttributeFromMap, typically Cd. Just write your alpha out as a black and white image and read in that file for the map.
Edited by Enivob - Dec. 7, 2016 23:29:54
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
