This is on Linux, with 8.0.383.
File COP, I want to read a file sequence with the following syntax:
foo 001.tif, foo 002.tif,…
which parses correctly in the file requestor to:
foo $F3.tif
(note the space). Problem is, this won't read the files - claims it can't find the file, red flag.
This seems to be related to a space coming just before a frame wildcard expression…having spaces elsewhere in the sequence seem OK.
J.C.
Sequential filenames with spaces
3016 3 0- JColdrick
- 4140 posts
- ben simons
- 387 posts
Hi John,
Same config: (Gentoo) Linux + Houdini 8.0.383
It works for me?! I copied two images to /tmp, naming them ‘thing 001.jpg’ and ‘thing 002.jpg’. After first trying a bunch of smarty stuff with lots of double backslashes before the space character (etc) i just ended up with something which works, lo: '/tmp/thing $F3.jpg'.
I quit Houdini, started again, and just typed in the latter expression, and it simply worked. I have a COP Viewer Pane open. Could it be a cooking problem?
Something (v8?) new: I also noticed the text entered on the FILE COP filename param line changes colour as you edit it (live parsing? whoa).
cheers,
bibm bahb.
cheers,
bibm bahb.
''You're always doing this: reducing it to science. Why can't it be real?'' – Jackie Tyler
- JColdrick
- 4140 posts
Aha - that at least helped me isolate the buggie. Yup, that *does* work, however there is an error that Houdini is performing with this particular situation. If I use the file requestor to load this sequence, Houdini is putting:
./thing $F3.jpg (1-2)
into the file field! In this case, 1-2 is the frame range of the test I'm doing. It doesn't do this with spaces elsewhere in the name. If I manually delete the ‘(1-2)’, it works fine.
BBQ Boy
BBQ Boy
John Coldrick
- andrewc
- 1002 posts
