Clusters and Point Constraints
5702 9 2- sascha
- 158 posts
- edward
- 7740 posts
- sascha
- 158 posts
- edward
- 7740 posts
Sorry, I don't understand. “Spline IK” as I understand the Maya terminology is just a “Follow Curve” bone chain in Houdini, isn't it?
If you want a more flexible means of capturing, there's always use of CaptureRegion SOPs.
Perhaps you can post an example hip file with some explanation of what you actually want done.
- sascha
- 158 posts
I get jumbled up between the Houdini terminology and the Maya terminology. Yep, the Follow Curve in Houdini is the same as the Spline IK in Maya. I want to set up a Follow Curve IK and want to drive the bone chain over the curve CVs. At the moment I know only one way to set this up. I plug every CV in a transform operator and set the handles to persistent or link the transformation channels to locator objects. Because I want to use the CVs (Clusters) in a hirarchy I need them as separete objects. In other words I need to fetch the Curve CVs as objects into the object level.
- Simon
- 2199 posts
- edward
- 7740 posts
- sascha
- 158 posts
Thanks Edward! I used the path operator, it does exactly what I need. Although I don't undersand what's going on in the path object and the pathCV objects the operator creats and how it is constructed. What about the pathCV operator? How can I use it? Is it possible to “convert” a curve afterwards into a path with pathCVs?
- edward
- 7740 posts
- sascha
- 158 posts
