Trying to simply bake out keyframes on a parameter that has an expression on it. What I've found in the forums seems wickedly convoluted. There has to be a simple and efficient way like in every other package out there, eg. right click on parameter containing an expression and bake it…done….right?
The “Bake Keyframes” seems to do nothing in my version. Hindie 15.5.673
Simple "Bake to Keyframes"?
1787 2 0- Tobias Steiner
- 101 posts
- jsmack
- 7803 posts
- Tobias Steiner
- 101 posts
jsmack
The channel needs more than one keyframe to bake, so that it can get the range for baking. An expression can be valid over all time, so baking range needs to be defined. You can either use the range override on the bake keyframe ui, or add a second keyframe at the end of the range to be baked.
That worked perfectly. Thank you!
