Trying to learn houdini and following tutorials shows how to use the old point node, but how do i use the new point node?
I would like to create Cd with expression (1-$PT/$NPT) in the red channel, however from my understanding that is hscript, and the new node is vex. Trying to use (1-@ptnum/@numpt) doesnt work, it just gives me a constant red value (i am changing the vexpression to value)
H16 point node
2017 1 0- Redcroft2
- 24 posts
- BabaJ
- 2040 posts
Your only doing integer math, which means results get rounded off (floored) to 0.
ptnum/numpt being integers only ever give 0(rounded), so 1-0 only ever give the 1 that you see for your results.
You need to cast the integers to floats, so you get the ‘fractional’ values.
Try this:
Try this:
@Cd = (1.0- float(@ptnum)/float(@numpt))
Edited by BabaJ - March 15, 2017 08:57:10
