How Can I Drive a Parameter in SHOP Network Using a Created Height Attribute?????
844 0 0- rangok
- 1 posts
I have made a custom shader using different noises and ramps … I have now created an attribute called Height and I would like the Height information to drive the values of “Hue Shift” in the SHOP network.
Basically,I am building a tower and would like to apply this 1 material I made to each of the units …but the units height attribute would override “Hue shift” in the SHOP network that way all the units colors will vary.
I am attaching screenshots and the Houdini file .
I just started with Houdini , so if you can modify my file or be detailed on how I could solve this issue I would greatly appreciate it !!!!
THANKS!
THANKS!
