Hi there,
i am haveing trouble getting a geo from Houdini to Unreal with two UVs.
What format exporter should i use?
Should it be tri mesh or can/should it be quads?
Thanks for any input!
kind regards
Olaf
Houdini to Unreal geometry prefered/recommended format/workflow
2273 2 0- Olaf Finkbeiner
- 323 posts
- aoakenfoArchiact
- 65 posts
- fragmentzero
- 9 posts
Hi
2 UV channels - I tested with 2 Layer SOPs with current layer set and Max layers set to 2. And it works when imported in Unreal.
Triangulation - I tend to use Divide SOP with default parms if I want to explicitly triangulate before export.
Export - Both FBX and Alembic works fine but Alembic is preferred in case of vertex anim baked stuff while FBX for ENV models.
Hope it helps.
Hope it helps.
