I'm new to Houdini and having trouble just placing simple geometry like a sphere into a scene.
My system configuration is as follows: up-to-date Windows 7, Intel HD Graphics 4600 (latest driver 10.18.14.4578, listed as supported in the help), 12 GB RAM
After installing and starting Houdini Apprentice Version 16.0.557 it always crashes whenever I put any node into the scene (like a cube, sphere, …). I submitted the crash log but like to ask for your advice now, as you maybe already have a solution. The crash log looks as follows:
Crash report from arettkow; Houdini Core Version 16.0.557
Uptime 27 seconds
Tue Apr 25 15:09:10 2017
Caught signal 11
Traceback from 6068 ThreadId=0x0000124c
CURRENT THREAD 4684
+0xdf1954ed
+0xdf05d4e9
+0xdf052320
+0x9432a9f7
+0x94308904
+0x94320fd3
+0x942aeb62
+0x942acd87
+0x942b5009
+0x535888af
+0x535864a4
+0x53586124
+0x5354ab7b
+0x5365df17
+0x53653cd9
+0x538190b2
+0x538169f0
+0x538188ce
+0x53818c50
+0x53811f78
+0x5381174f
+0x53810558
+0x537f0f01
+0x77d92409
+0x77d92812
+0x77d925f2
+0x77d92409
+0x77d92812
+0x77d925f2
+0x77e92a38
+0x77e970e3
+0x77e973e0
+0x537ea2e1
+0x77e314d5
+0x77e7b595
+0x77e0d634
+0x77e307ee
+0x77e2f252
+0x77e2f3a8
+0x93e5aff0
+0x93e5b6d2
+0x3fc5169f
+0x776759cd
+0x778aa561
Houdine crashes with a segmentation fault. I googled the problem but only got the advice to update the graphics driver, but I'm already using the latest one.
If there's anything more I could provide you (other log files, …), just tell me!
Houdini crashes when displaying geometry
5153 9 2- Alexander Rettkowski
- 3 posts
- Enivob
- 2563 posts
You need a better computer dude.
What you can try is to alter your Display settings and lock them in as the new default. Turn off all visual bells and whistles, mainly material display and any viewport effects. Turn off that fancy new grid as well, it is the culprit of some crashing.
This might get you past the crash on node creation but without a system that meets the minimum requirements you are just one click away from a crash. save often if you do get some work done.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- 3 posts
Doesn't my computer meet the minimum requirements? I thought I did.
I just tried Houdini 15 and it crashes with the same error. On my previous laptop (3rd generation Intel Core CPU compared to 4th on current, but Windows 10 instead of Windows 7) it runs fine, so it shouldn't be just the hardware, I assume. Installing Houdini 16 on the old one now and will let you know what happens.
What also might be interesting (regarding my newer laptop, of course): When I turn on wireframe mode before adding any geometry, it works fine and I can see in wireframe what I wanted to see. Switching back to the shaded view gives the same error as before.
EDIT: Ok so even Houdini 16 runs on my older notebook(Intel HD Graphics 3500, 4 GB RAM, Windows 10). So for the moment I can use this machine, but I'd prefer to have it up and running on the newer one with much more RAM..
Edited by Alexander Rettkowski - April 25, 2017 10:11:45
- neil_math_comp
- 1743 posts
Could you file a bug [sidefx.com] for the crash? It looks like an OpenGL shader-related issue, so possibly something with the graphics card/driver. It might be a little while before it gets looked-into, because the person with the best shot of figuring it out is on vacation right now.
- 3 posts
- DanielLassche
- 3 posts
- chrism
- 2496 posts
https://downloadcenter.intel.com/product/81496/Intel-HD-Graphics-4600 [downloadcenter.intel.com]
Make sure you have the latest driver, especially for Intel graphics cards. For win7 it's 15.36.33.4.578 and for win10 it's 15.40.34.4.624, according to the link above.
If it still crashes with the latest driver, please log a bug. Thanks!
https://www.sidefx.com/forum/topic/15603/ [sidefx.com]
Chris McSpurren
- DanielLassche
- 3 posts
- DanielLassche
- 3 posts
- FrancoisGressier
- 30 posts
I have the same issue here.
It was working fine on houdini through windows 10, but since windows 10 doesn't suits me I chose to switch back to windows 7.
On windows 7 everything works fine but Houdini's viewport, even maya's viewport works… I tried to reinstall the last drivers but it doesn't change anything.
Last solution, go back to windobe 10.
http://voxelfx.fr [voxelfx.fr]
