I am trying to complete a simple compositing operation - I need to multiply an image by a number. Seems trivial, but I can't figure out how to make a number…I've searched for things like “scalar, float, integer, constant” etc., but haven't found anything so far. By the way, I'm working in a cop2net…not even sure if that's the best approach.
Also, in a cop2net, is there a way to divide? I found all other typical math operations, but can't find divide.
Simple composite questions
1831 3 2- avoorhees
- 20 posts
- neil_math_comp
- 1743 posts
I can't remember if I've ever used COPs before, (apart from fixing a bug I introduced in rotoscoping), so I'm just guessing based on names from other contexts, but does the attached do something like what you wanted? (It's just a File COP and a Color COP both plugged into a Multiply COP.)
If you just want to divide a whole image by a constant value, you can multiply by one over that value, but short of using VEX/VOPs, I'm not sure what the right way is to do it if you want to divide an image by another image.
- avoorhees
- 20 posts
I've ended up using a color node to answer the first part of my question. Seems to work well enough.
I'm still trying to find a way to divide one image by another though. In img, I've found just about every other way to combine two images, but I can't find any way to divide.
EDIT: Oops, sorry posted that before I saw your reply. Is there a specific way to do this in vex? I found the vexgenerate node, but haven't found enough examples online to figure out how to do what I need with it.
Edited by avoorhees - May 15, 2017 14:05:04
- tamte
- 8555 posts
