Hi Everbody…
There is a question. Why mantra takes time to Render blank areas, even if there is no geometry, no fog, nothing.
I took a Cube, placed it in the middle of Camra View, one light, one camera. Camera set to 720 * 576. Thats it.
Even then it takes time to render blank space. And it is a considerable time. abt 5 sec to render the Cube and 15 sec to render the blank. Is there a way to reduce this problem. Or is there some specific setting.
Waiting for ur answer.
Thanking in advance.
——iamjaideep80
Mantra Render Problem
3614 3 2- iamjaideep80
- 82 posts
- andrewc
- 1002 posts
- pbowmar
- 7025 posts
- iamjaideep80
- 82 posts
Hi Everybody….
Thank u for replying.
I forgot to tell you the system config.
It is Xeon with 2 processors of 3 GHz .
2 GB RAM. And QuadroFX 1300 Graphics Card.
I don't think the problem is because of the system config.
I forgot to tell you that, for the Test rendering, I created Mantra out. and used
default parameters.
I think there is something that I should turn off or do some changes.
Or am I doing something wrong ????
Can u Explain????
—-iamjaideep80
default parameters.
Can u Explain????
—-iamjaideep80
iamjaideep80 (Jaideep Khadilkar)
