Drip particle fluid isn't colliding with ground plane?
   2232   3   1
Is this normal? or is there a way to fix this so that the droplets drip onto the plane and stop going through it?
Can you provide an example .hip file? I wasn't able to reproduce this issue on my end.
Thanks,
Ryan
hi Ryan, I've attached the hip file in question
Edited by valkias - June 6, 2017 23:52:06
blood.hipnc (2.0 MB)
It looks like your groundplane and drip simulation ended up in two different dop networks. I recommend moving the groundplane+merge+staticsolver set of nodes into the dripflip_sim dop network, wire it up to “merge1” AND move it above the flipsolver in the “Input Operators” list for “merge1”.
Ryan
