I want to recreate the seismic movement of the earth (earthquake) for building destruction. At first, I have recreated this movement through a python script that moves a ground plane in the x-axis. But, when I started the simulation, this didn't work properly. My question is if someone knows another way for earthquake simulation. I searched tutorials about the topic, but I haven't found anything.
Thanks,
earthquakes
2008 2 0- Josep Lluis Fita
- 21 posts
- Enivob
- 2536 posts
If you plan on using a python node to drive animation you will need to force cook it every frame in a ROP or any node that has a Scripts tab.
But why not just hand animate the x axis? What does the script do that is so unique?
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- Josep Lluis Fita
- 21 posts
