I'd like to understand why if I sim some packed primitives without UVs I have an output and if I sim the same packed primitives with UV's the sim looks different.
I already found a workaround for the situation: just select to import the points in the “dopio” and then I use the transform pieces node, but I'd like to understand the “why”
Cheers!
Packed RBD sims change the behavior with or without UV's
1212 0 0- merlino3d
- 65 posts
