Accesing Landscape in HDA
   3654   2   0
It is easy to get landscape if u make node level HDA. But how to make input for landscape if U got object level HDA? I got no idea
https://www.sidefx.com/forum/topic/42183/ [www.sidefx.com]
at the end of this topic there is example with solution
Yes, for landscape inputs on OBJ hdas, using an object merge and exposing its object path parameter (objpath) on the asset will give you an input.
Also, if you set the object path parameter's label to something containing “landscape”, “terrain” or “heightfield”, the input will automatically be defaulted to a landscape input in UE4.
