hey all
I'm trying to run houdini with 3delight or pixie .
3delight I got to render but I have problem with recognizing shaders .
I am under linux and use 3delight as renderer, following the instructions at
http://www.plastickitten.net/wordpress/tutorials/using-houdini-with-3delight/ [plastickitten.net]
but houdini always changes the .sl to .slo , even if the file is created by shaderdl (the shader complier for 3delight)
when I create shop from vop network , I cant preview the shader using 3delight (because it can't recongnize the .slo file).
how can I use houdini and renderman as the picture shows (Pixar's renderman is too expensive for learning):
http://www.sidefx.com/index.php?option=com_content&task=view&id=402&Itemid= [sidefx.com]
thank you for help!!!!
renderman renderer and houdini
4791 1 1-
- luozhiyuan
- 2 posts
- Wren
- 527 posts
