Are there any standards to adhere to for sending alembics to Nuke from Houdini? So far Nuke fails to read UVs and Quads properly. Currently resorting to using .obj for success
Thx!
abc from Houdini to Nuke
2911 4 1- anon_user_37409885
- 4189 posts
- sepu
- 419 posts
- 4189 posts
- sl0throp
- 258 posts
You can't see the uv's on a packed alembic until you unpack it, but they are there most likely.
A problem that I am having right now is that the alembics that comes from Nuke are that if it has a color attribute, that attribute is written as a single float value with large amounts of attributes, color1, color2, etc. I want to re-map the values but I am not sure how they eventually get the vectors on the points. I assume it must be something like every 3 floats corresponds to an rgb value that is tied onto the id attribute or something, which would mean that every 9 floats per point give a full rgb value…
If anyone has dealt with this and knows what I am talking about it would be great to see any workflows here.
- 4189 posts
