I am trying to manipulate the height of primitives by running a sphere over them. The closer the primitives are to the center of the sphere, the taller they become. Everything works fine when I manipulate the sphere manually, but when I keyframe the sphere's position, only the sphere's center position on the first frame is used for the calculations. I've been using wrangles/VEX for this.
I am using this line in a point wrangle to access the center of the sphere:
vector center = {`chs(“../../control_sphere/tx”)`, `chs(“../../control_sphere/ty”)`, `chs(“../../control_sphere/tz”)`};
Any ideas on why it's not updating every frame like I'm expecting?
Point Wrangle not using Keyframed Parameters
2852 2 1-
- doglesby
- 6 posts
- neil_math_comp
- 1743 posts
I'd recommend using:
Using backtick expressions in VEX code means that the VEX has to be recompiled every single time the expression value changes. Using the VEX functions chi, chf, chu, chv, chp, ch2, ch3, ch4, or chs, instead of the HScript functions ch or chs, means that it'll only have to compile the VEX code one time.
Also, double-check that the node path is correct.
Hopefully that helps you get it working. If it doesn't, please post a HIP file so that people can try to figure out what's wrong.
vector center = chv("../../control_sphere/t");Using backtick expressions in VEX code means that the VEX has to be recompiled every single time the expression value changes. Using the VEX functions chi, chf, chu, chv, chp, ch2, ch3, ch4, or chs, instead of the HScript functions ch or chs, means that it'll only have to compile the VEX code one time.
".."is the network containing the Point Wrangle. "../../control_sphere"is a sibling of the network containing the Point Wrangle, (i.e. two levels up, then a node in that network).Hopefully that helps you get it working. If it doesn't, please post a HIP file so that people can try to figure out what's wrong.
Edited by neil_math_comp - Aug. 13, 2017 11:35:32
- doglesby
- 6 posts
