Hi, what I want to do, as the title says, is to emit particles from an animated 2d texture. So far what i have acomplished, is to emit particles from a standard, non animated 2d texture, but i cant get it to be animated, i leave the files i have been working on, im sure is just a stupid thing that i have to turn on, but i cant find it.
Also if there is an easier way, or anothert way you may think i could acomplish the same effect just say it.
Thanks in advanced.
Generating Particles from Animated Texture
3085 2 1-
- seba00700
- 5 posts
- Sadjad Rabiee
- 1391 posts
You can just use constant parameters inside VOP networks ,So pointing to sequence textures via $F is not constant !
You should just promote map parameter of texture to outside of VOP network ,then address this to your sequenced textures.
This rule is same for ketframed parameters/Expressioned parameters and etc.
- seba00700
- 5 posts
Sadjad Rabiee
Thanks, that worked as expected
