In the 3D viewer's pane menu (Pane, Operator, Select, View) if you go to View->Shading-> then pick a shading model, it does not correspond to the bottom menu's selection, or that of the right stow bar.
For example if you try to pick wireframe from the top menu, it yields “wireframe bounding box”). If you pick “flat shaded”, it gives “Hidden Line invisible”. etc. It doesnt match up.
Secondly, I just noticed that the right stow bar's icon updates but the text selection does not. I.e. it has old information on the current shading model, even though the icon is up to date. The bottom icon does not have this problem.
Using WinXP, H 8.0.383
BUG: Viewport shading models
3315 4 0- scorpion007
- 21 posts
- edward
- 7715 posts
- scorpion007
- 21 posts
- edward
- 7715 posts
- scorpion007
- 21 posts
