EDIT:
Okay, just a few things with the object level path tool that I want to try and figure out: For one, is there any hotkey or anything that will -close- the curve when working at the top level (IE, while creating new points)? And also, I'm assuming there's a button for stepping back a point in the curve while creating points, but my searches haven't really turned up anything. Is there one?
3065 3 1- Vormav
- 33 posts
- Simon
- 2199 posts
The path object doesn't seem to like closed paths at all, something to do with it being a bezier curve. I think it would be an RFE even to have it work with closed paths at all let alone have a hot key for it. It needs various changes to the path creation network to get it to work.
As to stepping back through the path on creation I don't think that is allowed either. Just sling down your points and then move them to where you want afterwards.
- edward
- 7720 posts
- Simon
- 2199 posts
