Hi, I tried and this works for me, why the help document does not work, i do not know -ralph
import toolutils
# Copy the viewer's current flipbook settings flipbook_options = toolutils.sceneViewer().flipbookSettings().stash()
# Change the settings however you need # (for example, set the frame range and output filename) flipbook_options.frameRange( (1, 10) ) flipbook_options.output(“C:\\temp\\test.$F.jpg”)
# Generate the flipbook using the modified settings toolutils.sceneViewer().flipbook(toolutils.sceneViewer().curViewport(), flipbook_options)
