I am probably blind, but where exactly is the shader view in 16.5?
In the docs it is mentioned as a pane type, but when creating a new pane the shader view is not present (I have composite view, render view, material palette, etc. etc….but no shader view)?
Many thanks in advance!
Can't find the Shader View pane?
5343 5 0-
- DanFor
- 9 posts
- DanFor
- 9 posts
- Olaf Finkbeiner
- 323 posts
What are you looking for? “Shader view”?
Are you looking for the “mat” context?
The place to design shaders?
Your question seems like a simple question but the “houdini” language is sometimes not as simple.
maybe this helps: https://vimeo.com/215079619 [vimeo.com]
and read: http://www.sidefx.com/docs/houdini/shade/build.html [www.sidefx.com]
greetings
Olaf
greetings
Olaf
- robsdesign
- 240 posts
Hi, I can't find it in Houdini either but I did find a link to the documentation…
http://www.sidefx.com/docs/houdini/ref/panes/shaderview.html [www.sidefx.com]
Rob
Rob
- Doudini
- 333 posts
- DanFor
- 9 posts
