Is there any smart trick to recreate Modo Spikey function ?
See in attachment :
Left : Modo spikey.
Right : my current attempt, using 2 ‘divide’ operator (with subdivide + compute dual for the first divide, and convex poly for the second divide).
The result is fine for my actual needs, but I would love to know how to get the modo version (so without adding a level of subdivision)
Cheers.
Modo Spikey
1675 2 1- PascalBkm
- 17 posts
- tamte
- 8583 posts
Polyextrude
- check Transform Extruded Front
- Scale 0,0,0
- (use Distance or Translate Z if you actually need a spike)
- uncheck Output Front
Fuse
- keep distance very small just enough to fuse the tips
EDIT: tiny detail, set Polyextrude Divide Into as Individual Elements
- Scale 0,0,0
Fuse
Edited by tamte - Dec. 16, 2017 01:17:51
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- PascalBkm
- 17 posts
