Delete only column edges after skin SOP
3483
6
1
Hello guys, how i can keep only rows after skin SOP. See image attach. Cheers!
- tamte
- 8571 posts
depending on the direction you want to keep, set Connectivity on Skin SOP to Columns or Rows
Edited by tamte - Dec. 18, 2017 21:17:47
FX Supervisor
Method Studios, NY
Can you explain more clearly pls? Thank you!
Edited by Alex Kravtsov - Dec. 19, 2017 07:39:26
- tamte
- 8571 posts
It's a parameter directly on the Skin SOP node called Connectivity
FX Supervisor
Method Studios, NY
Yep, i know, but i need to bool this skin sop after…
Edited by Alex Kravtsov - Dec. 19, 2017 11:28:49
So i have solution for this. Just of using polywire SOP and then fuse SOP.
