Array between wrangle with attribute
1447
4
0
- Efi
- 45 posts
Sorry for my ignorance, but i'm really block.
I want use a variable whitch i defined in a other wrangle. So i put it in a attribute like that:
@radius[step] = set(result);
If whrite this
for debug at the end of the first wrangle it's work.
But in a other wrangle after it's not work.
Of course i have my attribute in this wrangle.
Radius is an array.
I dont' understand why?
I put the file if you need to see more about the code.
Thanks in advance,
180112_SuperFormula_v1_03_2D.hip (71.7 KB)
Jeremy Gurdal
VFX Artrist
- sepu
- 421 posts
it works on my side. 16.5.268
- Efi
- 45 posts
really on the second attribute wrangle “attribwrangle7” ?
do you have change something ?
Warning maybe the print at the end of the first wrangle is not comment ?
Edited by Efi - Jan. 12, 2018 13:35:48
Jeremy Gurdal
VFX Artrist
- sepu
- 421 posts
I didn't change anything
- Efi
- 45 posts
okay thank you.
Maybe is the version i'm on 16.0
Edited by Efi - Jan. 13, 2018 10:45:32
Jeremy Gurdal
VFX Artrist
