ok i have two PC's one at my home and its Profile is
2.4 Intel Processor
Nvidia (With Chip MSI on AGP Slot ) FX 5900 128 MB Graphic Card
Two Hardisk of Simple Hdd 120GB+120GB
and Windows XP SP2 Pro Installed
Installed Houdini 8 and Runs Very Good Even when i use keyframes Play Smooth and Not any Problem
Now System i have in my Office - Profile is
3.2 Intel Processer
Asus Ax600 Pro SE 128 MB in PCI 2 Slot Graphic Card
Three (3) Sata Hardisks 200GB + 200GB + 120GB
Windows XP PRO SP2 Installed (Same as on my 1st PC)
Now Problem is this When i use keyframes and play then Playback is very Slow and Looks Like Very Heavy or Somthin Even i have Upgraded already Drivers but i dunno what to do (one more thing when i instert a new geometry then the default box in geometry when i use mouse to drag or move it its also like same very slow or somthin )
so is there any Cofiguration i have to do or what my Card is Supported or Not or What. anyway i have Houdini 8 (474)
Need Realy Help
Regards
Ali
Graphic Problem or Configuration ? (Help)
4931 10 0- majnoo
- 30 posts
- edward
- 7766 posts
- majnoo
- 30 posts
- edward
- 7766 posts
Sorry, reading that Asus part didn't register in my mind as a video card. It's usually more common to describe video cards by their underlying chipset. So your second computer has a ATI Radeon X600 XT. See this page for some video driver recommendations:
http://odforce.net/wiki/index.php/GraphicsCardIssues#ATI_Catalyst [odforce.net]
BTW. If you don't mind the work, you can rule out the video card problems if you're willing to swap the video cards and go through all the trouble to re-installing video drivers.
- majnoo
- 30 posts
- majnoo
- 30 posts
- edward
- 7766 posts
- majnoo
- 30 posts
edwardi don't get your point but i have tried all drivers for my card and they all work fine on 3d or for all applications but Problem Still Continue with Houdini. is there anything i have to change from Windows , Houdini Perfomance, Or from Bios or from my Card Configuration Just Let me Know
You mean you've tried swapping video cards too?
Thanks For Your Reply
Regards
Ali
- djorzgul
- 234 posts
ati generally has crappy drivers, well crappy open GL in fact… why, I don't know, but, a BIG butt
I must recomend this guy, 'cause all my open GL related problems where gone when I installed his drivers. I work mainly, still, :x , in Maya, so various glitches were present with official ati drivers, with omega ones, ZERO problems, it may help with Houdini, who knows…
link:
http://www.omegadrivers.net/ [omegadrivers.net]
link:
- edward
- 7766 posts
- majnoo
- 30 posts
