I've been unsuccessfully trying timeshift and solver nodes to store the previous value of a detail attribute. Not the value on the previous frame, but the previous different value. From what I've read, I am quite sure Solver node is the way to go, but I cannot come up with a solution inside the solver. Any ideas?
Set an attribute with the previous value of another attribute
2039 7 1- perpen
- 59 posts
- Tanto
- 396 posts
- perpen
- 59 posts
Here's a file with my setup. I have a camera animation and 10 fixed cameras. A detail attribute stores the best (closest angle) fixed camera compared to the camera animation. Then I have a trigger value (detail float) that switches to 1 every time “camera1” detail attribute changes its value. My ultimate goal is to make that 1.0 trigger value, fade to zero in (let's say) 5 frames, instead of going back to zero the next frame. So i can use it as a blending value, every time there is value change in the “camera1” detail attribute value.
- jsmack
- 7773 posts
- perpen
- 59 posts
- Tanto
- 396 posts
- perpen
- 59 posts
- Tanto
- 396 posts
