how do I get parameter and network panes side by side instead of stacked?
   1088   3   0
I had it set up once but had to reformat my drive and can't remember how I got them side by side so how is it done? I managed to get the scene view on the second monitor.
Hey bobc4d,
in the upper right corner on every pane, there is a little arrow. click it and locate the option split pane left/right.
Cheers
Philipp
Depending on your desktop layout, Alt-LMB on the middle of the bar separating those panes may be the quickest way. This toggles them between stacked and side-by-side.
PERFECT pabcou, that is what I was after. thank you so much. now to burn that into memory.
