I’m having a small problem with creating an HDA to automatically import an animated camera from Maya. If I do it manually it works fine. Manually I take the following steps:
- File > Import > Alembic Scene > Select the exported alembic camera from Maya.
- I add a Null to the Alembic Archive and change the Uniform Scale to 0.01.
- I create a CHOP network and inside I create: Object (Import), Fetch, Merge and Export nodes.
- I create an camera in /obj and name it RENDERCAM.
Then inside the CHOP network I set the following settings:
Object - Object tab - Object (Import) - Target Object = shape of the imported alembic camera.
Object - Object tab - Compute: Position and Rotation
Object - Channel tab – Channel Range: Use Full Animation Range
Fetch – Source tab – Node: shape of the imported alembic camera.
Fetch – Source tab – Channels: focal aperture
Export – Export tab – Channels: t r focal aperture
Export – Export tab – Node: /obj/RENDERCAM
Export – Export tab – Path: t r focal aperture
If I then click on the export flag it Exports all the correct information to the RENDERCAM.
Now the way I thought of building the HDA is by creating a subnet of the Alembic Archive, Null and Chopnet. In the Chopnet I create a switch before the export where with 1 the export flag is off and the other export the flag is on. Also, on every common tab of these nodes I remove adjust the Export Prefix to ../.. so there are no references outside subnet. I really don’t know for sure if this is correct.
So the problem I’m encountering is that when I select the Alembic Camera from the Subnet where I created a “File” link, it doesn’t build the hierarchy and thuis I cannot select the shape and so forth.
Please see attached my setup and the alembic camera. Anyone have any ideas of how to fix this or how to set this up better?
Danny
