I'm trying to import numpy and other python modules so I can use them in Houdini for expressions.
I tried using the paths defined at ‘Python Script locations’, http://www.sidefx.com/docs/houdini/hom/locations.html [www.sidefx.com]
but these paths do not appear to be defined on the Mac. I launched Houdini Terminal and printenv shows
HFS=/Applications/Houdini/Houdini16.5.473/Frameworks/Houdini.framework/Versions/Current/Resources
H=/Applications/Houdini/Houdini16.5.473/Frameworks/Houdini.framework/Versions/Current/Resources
HB=/Applications/Houdini/Houdini16.5.473/Frameworks/Houdini.framework/Versions/Current/Resources/bin
HDSO=/Applications/Houdini/Houdini16.5.473/Frameworks/Houdini.framework/Versions/Current/Resources/../Libraries
HD=/Applications/Houdini/Houdini16.5.473/Frameworks/Houdini.framework/Versions/Current/Resources/demo
HH=/Applications/Houdini/Houdini16.5.473/Frameworks/Houdini.framework/Versions/Current/Resources/houdini
HHC=/Applications/Houdini/Houdini16.5.473/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/config
HT=/Applications/Houdini/Houdini16.5.473/Frameworks/Houdini.framework/Versions/Current/Resources/toolkit
HSB=/Applications/Houdini/Houdini16.5.473/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/sbin
HOUDINI_MAJOR_RELEASE=16
HOUDINI_MINOR_RELEASE=5
HOUDINI_BUILD_VERSION=473
HOUDINI_VERSION=16.5.473
HOUDINI_BUILD_KERNEL=17.0.0
HOUDINI_BUILD_PLATFORM=Usage: sw_vers
HOUDINI_BUILD_COMPILER=9.0.0.9000037
HIH=/Users//houdini16.5
HIS=/Applications/Houdini/Houdini16.5.473/Frameworks/Houdini.framework/Versions/Current/Resources/houdini
but no paths for the pythonrc.py file.
Suggestions?
Thanks,
Tom
Importing custom python modules on Mac: pythonrc.py file location?
825 0 0- astronomertom
- 13 posts
