Hey
I need to create a falling paper with one corner burning. Originally I created my falling paper using cloth, and I blasted some polygons from the corner to use as emitter. As a static object, it burns pretty well. As I apply cloth dynamics, it won't burn, the bounding volume of the fuel disappears after the first frame
I tried to find a tutorial how to make this, in vain.
What's the suggested method to solve this task?
Pyro and cloth
1225 2 1- szmatefy
- 141 posts
- Tanto
- 420 posts
Hey!
Some things your might try if you haven't already:
In your resize container node, make sure clamping in the Max Bounds tab is disabled or set up to contain your whole animation.
Also, if your emitter moves too fast, it might leave the simulation's bounding box; in the Bounds tab, increase your padding or use your animated emitter in the Tracking Object tab.
- szmatefy
- 141 posts
