How to find nearest primitive
   9143   3   1
Hi Guys ,
I need to find the nearest primitive using VEX,basically looking for something like nearpoint function in VEX,but for primitive,I am getting the output using Attribute transfer,but want to do it using VEX.
The scene is such that I have two exact same spheres with same topology.One have primitive based color and I want to transfer the primitive color from one sphere to another using VEX
xyzdist() will give you nearest primitive (as well as exact uv location within) to provided position
xyzdist() is usually used for looking up the right primitive number along with its intrinsic UV-coordinates.
primuv() is used then for grabbing attributes from exactly that location.
Hit play to see it in action:
xydist_example.hiplc (130.3 KB)
Thanks alot guys …It works great!!Cheers!!
