Hi all, i'm trying to sort my object primitives accordingly but no matter what I do, the corner faces of my object get sorted after the faces.
What am I doing wrong?
Sorting primitives problem
958 1 0- DarKhar
- 1 posts
- Aizatulin
- 475 posts
the reason is, that you have merged the corner prims into the box after you created it. If you change the input order of the merge node, you can see that the corner prims will be added first. If you want to change this, you have to change the combo box input of the sort node (primitive sort) to something else (for example by Y). The advantage is, that you can use prim attributes aswell (which has to be defined before) to gain more control of the sorting order. For example you can use a combination of the y value and the angle in the x-z plane (which can be obtained by the shortest distance function xyzdist to a circle).
