I am trying to create an HDA with dynamic Python menus. I can access parameters from nodes, but I don't know how to access attributes.
This works and prints out the appropriate value
geo = hou.node('/obj/geo/pythonMenu/box')
test = geo.parm('tx')
print test.eval()
Using an Attribute Wrangler I created a string, from some primitive attributes.
s@prim = detailintrinsic(0,“primitiveattributes”);
prim contains
I want to use prim in a for loop to populate the menu
I need to generate a string like
token = 0
menu
for x in prim:
menu.append
menu.append
I tried geo.attribValue("prim'), from a forum post. But, attribValue is not a valid method.
I attached the project, but the main issue is how to interact with attributes with python.
Brad Carvey
Python HDA attributes
1747 1 1- bradcarvey
- 52 posts
- jjayakumar
- 106 posts
Hi there!
“attribValue” is a method from hou.Geometry class. so you need to get the attribValue from the node Geometry instead of the node.
This should give what you're looking for.
Hope it helps
Cheers
-J
node = hou.node('/obj/geo/pythonMenu/box') geo = node.geometry() geo.attribValue('prim')
Hope it helps
Cheers
-J
Edited by jjayakumar - Sept. 26, 2018 11:06:32
