Hi!
I have 2 almost identical triangles (each from a different node) and I need the @ptnum to be consistent.
I would always want to have the point that has the smallest angle to be point 0. …and to always have the next point on the longest edge to be point 1 and the last one be point 2.
I'll be good with figuring the angles and the edge lengths. I just don't get how to change @ptnum from there…
Any ideas on this?
-Olivier
change @ptnum assignment in specific order
2689 2 0- olivierth
- 1010 posts
- olivierth
- 1010 posts
- olivierth
- 1010 posts
Ah! found it!
I ended up just ordering the point number from smallest angle to biggest angle. (finding longest edge was useless)
// find Positions
vector p0 = point(0, “P”, 0);
vector p1 = point(0, “P”, 1);
vector p2 = point(0, “P”, 2);
// find edge lengths
float ab = distance(p0, p1);
float bc = distance(p1, p2);
float ca = distance(p2, p0);
// find vectors to next points
vector vab = normalize(p1 - p0);
vector vbc = normalize(p2 - p1);
vector vca = normalize(p0 - p2);
// find vectors to previous points
vector vac = normalize(p2 - p0);
vector vba = normalize(p0 - p1);
vector vcb = normalize(p1 - p2);
// find angles using each vectors
float aglA = acos(dot(vab, vac));
float aglB = acos(dot(vba, vbc));
float aglC = acos(dot(vca, vcb));
// set point value from angle A, B, C
f@angle = 0;
setpointattrib(0, “angle”, 0, aglA, “set”);
setpointattrib(0, “angle”, 1, aglB, “set”);
setpointattrib(0, “angle”, 2, aglC, “set”);
From there, I use a sort SOP and use the by attribute and use @angle.
// find Positions
f@angle = 0;
Edited by olivierth - Sept. 26, 2018 14:49:49
