Vex: read tuple of ints with detail expression
   1825   3   0
Here is a minimal example.
An attribute wrangle node with the following snippet:
i[]@test = {2, 4, 6, 8}
Now i wan't to access in the blast node that list, so i use the following expression:
detail("../attribwrangle1", "test")
However detail expect's an `index` as the last parameter, so doing
detail("../attribwrangle1", "test", 0)
will return `2`, which is the first element.
Is there a way to return everything as a list/string?
Edited by schiho - Nov. 1, 2018 16:56:08
To keep as close to your workflow.
Instead of creating an array of ints in the detail,
create a string:
s@List = '0 1 2 3 4 5 6';
If instead of manually creating the string, you need to use ints like @ptnum, you can first contstruct a loop using itoa() and append() functions to get it to a string.
Then for the blast node use the following(needs those backticks):
`detailsmap("../PW/", "List", 0)`
Middle mousing the parameter box with the detail function will go between what it evaluates to and the expression itself.
Blast with Detail String.hiplc (71.4 KB)
interesting question, I thought you could do something like this `atof(details(“../mywrangle/”, “mystring”, 0))` but it seems broken.
@BabaJ
Thanks a lot, that's what I was looking for, did it a little different though, as I'm now accessing only a string.
`details(""../attribwrangle1", "test")`
