Hi everyone !!
I try to bake texture by Render to disk But The texture i got it with out gamma 2.2
and when i try to render to MPlay The texture i got it come with gamma 2.2
That make me so confuse.
and if i got that texture with gamma by bake texture node. It mean the texture color is same color preview right ?
Did i miss something?
Thank you so much!!!
How to Bake Texture With gamma by Render to disk
1719 3 0- akadet
- 8 posts
- dlee
- 425 posts
When you render to mplay, the actual data is linear and it's applying gamma only upon display (see “2.2” on the control bar near the bottom of mplay window). Bake texture will non-linearize when you extract as 8-bit image (tga, png, etc). You can also choose which image planes will be excluded from this process with “extracted linear planes” parameter (under Advanced->Driver tab). If you're still having problems, please post your .hip file here.
- akadet
- 8 posts
- dlee
- 425 posts
You'll notice that, by default, it contains list of expressions and they are comma-separated. Each expression evaluates image plane name from UI (you can tell that the first expression is for ‘Nt’ plane since it mentions ‘Nt’). You can scroll through the list and remove the expression that contains the plane name that you want to non-linearize. Conversely, if you want to keep an extra plane linear, you can simply scroll to the end of the list and type comma and the plane name at the end (you don't have to use an expression).
