i attach a hip file.
there is a circle and boxes that's created using copy SOP.
in the copy SOP i turn on the ‘rotate to template normal’ parameter so it will follow the orientation of the point normal.
in viewer there is a handel that's persistent. so when i drag this handle in y direction up or down , the normal will follow , but some of the boxes is rotating in wrong direction.
so i want all these boxes to rotate ‘inside’ to follow the normal.
another question: when create a curve SOP, how to reorder/reverse the point number?
pls help.
thanx
3072 3 0- metaclay
- 122 posts
- wolfwood
- 4262 posts
- wolfwood
- 4262 posts
metaclay
thanx
On your Point SOP, on the Particle Tab, add an Up Vector of (0,1,0). That will give your Copy SOP a frame of reference which will keep the objects from spinning all over the place.
- metaclay
- 122 posts
