Noobie question here, I try to make a procedural fence but polybevel won't work on my line. I try the convert node but it doesn't help. Here is a screen of my workspace, it maybe help :
I made two lines, group 2 points, connect them with add, and add another group of all the points, then the polybevel.
What am I doint wrong? I don't understand why the polybevel work on curves but not on a line made of points.
Polybevel doesn't work on line
1916 4 1- kentin
- 22 posts
- jsmack
- 7767 posts
- kentin
- 22 posts
- jsmack
- 7767 posts
kentin
Ok, so how could I make it one line ?
Are you sure it's 3 lines? In this case I should have 6 points instead of 4 I think.
Nope, 3 lines can share points and so still have just 4 points.
In your case, the simplest way to build a single curve from the segments is with
Edit:
The join sop does not remove redundant vertices.
Edited by jsmack - Jan. 19, 2019 13:14:00
- kentin
- 22 posts
