assign a global variable with python
   1614   2   0
Hi
i want to assign a global variable as path for a rop node with python - but the problem is that python translates the string $F to the current frame, and every other parameter… but i want to assign $F without translation
node_rop.parm('sopoutput').set(“$JOB/render/$HIPNAME.$F.bgeo.sc”) gets translatet to /Users/xxxx/Project/render/path.12.bgeo.sc in the rop network
so how can i assign a $F to a textinput field with python
thank you for help!
seet attachment
pythonRop.hiplc (64.4 KB)
just escape the $ character
node_rop.parm('sopoutput').set("\$JOB/render/$HIPNAME.\$F.bgeo.sc")
FX Supervisor
Method Studios, NY
tamte
Thank you very much!
