Houdini 8.1 documentation:
Edit an object's origin/pivot:
To…
Set an object's pivot point in the viewport
Do this
TBD.
Where is the pivot orientation?
3404 3 1- sascha
- 158 posts
- wolfwood
- 4262 posts
- sascha
- 158 posts
- wolfwood
- 4262 posts
sascha
Like you do it in Maya or XSI. The only difference is the other applications have a rotation for the pivot or center.
Well if you need the “pivot” to have a rotation you could just parent a null to the object. From there you could transform and rotate that null, and since its the object's parent it will act as the center or “pivot”.
