Aligning Rotation
3627 4 1- sascha
- 158 posts
- wolfwood
- 4262 posts
- sascha
- 158 posts
Wolfwood
As stated in your other thread,Simon
Detach the handle, then right click on it and use start orientation picking - then pick 3 points.
I see it's not so easy coming from XSI and Maya.
The problem is if I pick the CVs the position does also snap to a new location. I just want to align the rotation.
Also I want to pick vertices from the lattice itself which does not work.
- wolfwood
- 4262 posts
sascha
I'm not sure what you are trying to do. Are you trying to model an object and want to align the handle in different ways to make pushing/pulling points easier? Or are you working with Objects and trying to create a rig with specific spaces and orientations?
- sascha
- 158 posts
Wolfwood
Yep, I want to align the edit SOP handle for example.
