Exporting a texture on a multi-layered object?
   1313   0   0
Hello all!
So right now I have a pretty simple "Power plug' model, the idea is that I have two components, the metal bit of the teeth and the plastic bit of the handle part.
I have them merged and both the metal and plastic texture are separate, what I need, is to either merge the two textures into one output that can be referenced later, or to export the material on the unwrapped model so that way when I plug the model into an instance later, the materials will just be applied normally as one.
