I am following the tutorial “CREATE A TASK WORKFLOW TO BUILD CITIES” by Robert Magee of side/FX to the point of cooking the HDA Processor. The work item display turns red with no further error messages. Just saying: “failed 1” in the info box.
I tried the same thing with a new file and an example from the side/fx website (“example_top_hdaprocessor”)and got the same result. The node cooked, the work items display became green as normal and short before finishing changed to red.
Anything else in TOP's works great. This technology is awesome!
Is the Apprentice version of Houdini unable to work with HDA's in the TOP HDA Processor?
I am using Houdini Apprentice 17.5 with Mac OSX 10.14.2 on an iMac 27 inch late 2012.
Uli
TOP HDA Processor not working in Apprentice version?
5891 6 4-
- HoudiniUser2
- 3 posts
- HoudiniUser2
- 3 posts
Here is the error log:
Returned error code 1:
hda name: /Users/Uli/Desktop/tops_lesson_start/hda/Uli_test2.hdanc
operatortype: Sop/Uli_test2
Could not load /Users/Uli/Desktop/tops_lesson_start/pdgtemp/54028/Uli_test2.hdanc
HAPI Error: No Valid Licenses Found
- HAPI_LICENSE_MODE unset or is set to ‘default’ meaning Houdini Engine will first try to acquire a Houdini Engine license and if one is not found it will try to acquire an interactive Houdini license (Houdini Core then Houdini FX).
- No Houdini Engine license found.
- No Houdini license.
- Found a Houdini FX (Houdini Master) license but it is not the required commercial variant.
- No Houdini Engine Indie license found.
- No Houdini Indie license.
- kenxu
- 544 posts
- HoudiniUser2
- 3 posts
Hi Ken,
thanks for the answer.
The PDG FAQ says:
Q | Can I use PDG in Houdini Indie and Houdini Apprentice?
A | Yes. Houdini Indie can access PDG using Task Operators to distribute tasks to a small compute farm using up to three Houdini Engine Indie licenses. PDG is also available in Houdini Apprentice for learning purposes but only works with the local scheduler to process tasks on the computer running Apprentice.
That means PDG is woking in Houdini Apprentice with the exception of the TOP HDA Processor Node?
The PDG FAQ says:
- kenxu
- 544 posts
- kahuna031
- 897 posts
- chrisgreb
- 603 posts
