How would you wedge multiparms?
3055 3 0-
- DASD
- 490 posts
- DASD
- 490 posts
I just realized I could add a bunch of blocks and wedge on/off toggle parameters per block. That way I could wedge the parameters contained within those blocks and still vary the amount of the blocks.
It seems like we should be able to do a more procedural solution though. Because you would not want to manage dozens or even more such blocks manually.
- kenxu
- 544 posts
Varying the number of multiparms might not be too bad, but filling in their contents would be more challenging - the multiparm instances would not even exist until runtime, and so we have no way yet to specify what should go in them before runtime. As a work around, would it work if you specified the maximum number of multiparms in the HDA, then proceed to fill in the contents with the regular @syntax for each instance?
- Ken Xu
- DASD
- 490 posts
